02-26-2022 09:46 PM
Wired Doorbell and its camera repeatedly goes offline almost a week or two after restart. Each time the it goes offline, LED is still solid green, so it should mean is connected, but it isn’t on the app and does ring. Checked Wi-Fi signal remains strong. But the problem remains.
This is beyond frustrating as nothing changes and we do not have issues with out wifi connectivity ever. Currently….The camera is offline, has a solid green light, no light around the button and no feed on either the nest or google apps. When I try to reboot it nothing changes and trying to reconnect through the app does not work- the circle just spins and spins!!!
Seems like firmware freezes although the outdoor temperature is -6C well above-20C operating condition.
google nest there must be a remedy? Been living with this problem for a year…
05-03-2022 08:48 PM
Hey Manomon,
We hope you were able to get the help you need but if you're still having trouble, you might want to check out this link for additional information.
If the issue persists, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Archie
