Nest wired doorbell on front door and old nest hello on side door. How to wire the second?
Videofrank
So I have an old Nest Hello from the front door that I just upgraded to Nest wired doorbell. I installed the new one and it's working. I'm now going to replace the old school push button style doorbell on the side door with the old Nest Hello from the front door, rather than just throw it away. I have two chime boxes, one for the front door and one for the side door. The chime for the side door has more wires than the one for the front door. It has two red wires going into the screw labeled "front", two white wires going into the screw labeled "trans" and one red and one green wire going into the screw labeled "rear". How am I supposed to use the Chime connector with the chime box for the side door?
Videofrank
I figured it out already.
Thanks.
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. I would love to look into this further for you. Here is a great article that goes over things to consider when installing your device, wiring, power requirements, etc. and I think you could find it quite interesting and helpful. Please let me know if you need further assistance.
Videofrank
Thanks.
@Videofrank
I am relieved to hear you were able to figure it out! I will go ahead and mark this thread as resolved. We'll keep this open for another 24 hours for any follow-up questions or concerns.
