05-17-2023 02:59 PM
I have 2 Nest cams that I've had for a few years. For years it worked properly: when I left it said Away and turned on; when I returned it said Home and turned off. The app still reports Home and Away correctly, but this has no effect on whether the cams turn on or off. The only way to turn the cams on is to switch them manually; the only way to turn them off is to switch them manually. Home/away simply doesn't affect the cam, even though the app records my location correctly. How can I fix this?
06-17-2023 03:53 PM
Hello KarenHF,
Thanks for reaching out here in the Community. To confirm, what are the troubleshooting steps you've done so far? Which Nest Camera do you have? Try turning off and on your Home and Away assist settings. Reinstall your app and let us know how it goes.
06-21-2023 07:10 AM
Hi KarenHF,
I'm dropping by to ensure that everything is covered here. How's it going with your Nest account? We would appreciate it if you could share the information I’m asking above. Also, were you able to perform the steps I’m suggesting? We'd be glad to hear from you.
06-22-2023 07:55 AM
Hey KarenHF,
Just one final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
