04-16-2023 01:53 PM
Just received my replacement Nest Cam for my Drop Cam. Plugged the new one into a USB port on my PC and it blinks yellow. Plugged it into every USB port on the PC and only will blink yellow. Hard to believe that none of my USB ports have enough power. How do I get this new Nest Cam up and running with my others?
04-16-2023 03:17 PM
I believe you probably received a 2nd gen Nest Cam (indoor, wired) as your replacement camera. Google Nest decided that the new Google Nest cameras and doorbells released starting in Sept. 2021 would NOT work in the Google Nest app or on the home.nest.com website. You will have to install your new camera in the Google Home app:
https://support.google.com/googlenest/answer/10931419
You'll be able to view the camera's livestream on the "preview"/beta home.google.com website, along with your other Google Nest cameras and doorbells.
04-16-2023 04:02 PM
That is good to know - wish the upgrade notice had mentioned that. However, I haven't even got to an app - plugging in the Nest Cam produces a yellow blinking that indicates low USB power which means no app is even going to find the camera for installation. Any thoughts on that? Thanks!
04-16-2023 04:05 PM
One other thing: I did go to "preview"/beta home.google.com website and could see my remaining Nest cameras. But there doesn't seem to be a way to add a camera to it. Am I just missing it?
04-16-2023 04:46 PM - edited 04-16-2023 04:47 PM
You do NOT plug your Nest Cam (indoor, wired) into any USB port on your computer. (We have one.) You plug it into a wall outlet using the round power adapter that came with the camera.
Then you install the camera in the Google Home app on your phone or tablet, using the instructions in the link I provided above.
Have you migrated your Nest Account to a Google Account? (We migrated a couple of years ago.) If not, you should do that first. If you install your new camera in the Google Home app before migrating, then you will not be able to migrate your Nest Account to that Google Account. (https://support.google.com/googlenest/answer/9297676)
The home.google.com website is in "preview" mode with limited functionality, and the only thing you can do there is view your cameras.
04-22-2023 08:54 PM
Checking in — I just wanted to make sure if you’ve seen MplsCustomer’s reply. Let me know if you need anything else
04-25-2023 08:55 PM
Hey paulvonfange,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
04-26-2023 10:46 PM
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
