12-23-2024 09:41 AM
Hi all,
I recently purchased a new Nest doorbell (battery) and attempted to connect it today.
Every time I try to get it connected to WiFi using the Google home app it fails/times-out.
I tried the following:
Still no luck... I checked the forum but mainly find issues of doorbells working first and having trouble later. I will probably return this device and get a new one but wanted to try and get some support here first.
Thanks!
12-24-2024 08:57 AM
I just split the 2.4 and 5G wifi signal from my zyxel T56 modem into two seperate wifi signals and tried connecting to only the 2.4G wifi (5G did not even show up).
But still no success.
12-25-2024 02:58 AM
Stumbled across a forum of my internet provider (Odido NL), it seems to be related to the settings in their modems. As soon as I have time to check if it works I will link the forum here.
12-26-2024 11:19 AM
Hi JordyNL,
Thanks for reaching out to our community.
I’m sorry to hear that every time you try to connect your Nest doorbell (battery) to your WiFi network using the Google Home app, it fails. Thank you for sharing with us the troubleshooting steps you’ve tried to resolve the inconvenience so we can advance with more alternatives. No worries, help is here.
I also appreciate you letting us know about the information you found about your ISP (Internet Service Provider); I will be aware of your news on this matter.
It is my pleasure to assist you in resolving the inconvenience you’re facing trying to connect your Nest doorbell (battery) so we can try on our side to find a solution. Before I start further troubleshooting, let me ask you a few questions:
Besides the previous information, I would appreciate it if you could verify the camera’s battery state. Please follow the next instructions:
Thanks for your kind attention; I will be looking forward to your response.
Virna
01-06-2025 12:49 PM - edited 01-06-2025 12:51 PM
@JordyNL wrote:Hi all,
- Turn off/on phone
- Reset my internet connection
- Turned off 5G WiFi (only 2.4G active)
- Sat close to the wifi router
- No wifi extensions/repeaters etc
- Factory reset the doorbell
- All of the above at once
- Tried connecting the doorbell at a different adres and WiFi
Thanks!
Issue is resolved!
Root cause were the settings in the ISP Odido NL router, which did not allow for the nest equipment to connect.
ISP remotely changed the settings after requesting it via this Link to their forum. That combined with the phone wifi hotspot workaround (connecting the doorbell to hotspot with identical network name and password) made it work.
But in the end I decided to switch to a TP link router instead because it's just more user friendly.
