No light control feature on my Nest floodlight cam
JustJessy
I recently purchased and installed a Nest Cams with Floodlight. Worked fine for about a week but then the light controller went away.
Now the Floodlight option in Device Features is gone along with the ability to change the timer on the light, and it also doesn't show as a light in Google Home. The light still comes on with motion but can't do anything to control it manually.
I removed and re-added the camera, but it still doesn't show the Floodlight any help is appreciated.
Rshane76
I have the same issue but sunce I restarted the camera there's no power indicator on and I can't do a hard reset. I deleted the camera from the app but I'm not getting anything now! Help
Terrible! I'm sorry to hear this is happening to you. This looks like it's a common issue reading posts off reddit. I was hoping to get some help, but got nothing. I'm just planning on returning my two cameras I bought. To think I wanted to get 3.
Derickf
Thank you for posting in the community. I'm sorry to hear that the Floodlight controls disappeared, even though you tried removing and re-adding the Nest Cam with Floodlight from the Google Home app. Don't worry; help is here.
To gather all the necessary information and provide you with the best assistance, please answer the following questions:
  • Are the Google Home app and your phone up to date?
  • How far is the Nest Cam with Floodlight from the router?
  • Have you tried removing and reinstalling the Google Home app?
  • Could you please share with me a screenshot of how the Floodlight appears in the Google Home app?
I'll be waiting for your reply.
Best regards.
Derick.
