04-21-2022 06:41 PM
Hello, the small round piece of glass on my outdoor nest camera is broken. Is it possible to order a replacement? The camera works fine, it’s just that piece of glass over the lense that needs to be replaced.
05-18-2022 10:02 AM
Thank you for your patience. We do not process these requests in the Nest Community Forums. If you are seeking a replacement, please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number.
05-23-2022 10:01 AM
Hey Folks.
