02-26-2023 06:45 AM
How many charge cords or chargers are included in the Nest Cam Outdoor battery 2-pack model? I lost one of mine and not sure if I lost both or just one? I believe they were USB-C and would like to replace it.
02-26-2023 07:20 AM - edited 02-26-2023 07:23 AM
The 2 pack comes with one 1m (3.3ft) charging cable, and one power adapter. The cable itself is not USB-C, it's a proprietary cable designed for Nest Cam (battery). It's available on the Google Store.
Nest Cam (battery) Charge Cable
Worth bearing in mind the charge cable is not weatherproof, so don't use it outdoors. If you're using them outside, I'd strongly recommend getting the weatherproof cable instead.
02-26-2023 08:03 AM
Thanks! It looks like the weatherproof cable is what I need.
03-02-2023 10:36 AM
Let me know if you need anything from me, but I am just seeing how the conversation is going. Thanks for the help here, davidking!
03-06-2023 10:11 PM
03-05-2023 10:06 PM
Hey falcon,
I appreciate your help here, davidking and Brad.
02-26-2023 08:24 AM
No problem!
