Quiet time doesn't stop chime signal
damador
Quiet time does not silence chime signal. 2 battery versions have worked correctly. Wired 2nd gen ignores quiet time setting and still triggers doorbell. I have tried resetting device and checking all wiring. Doorbell simply continued to send chime electrical signal.
29 REPLIES 29
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. I would love to look into this further for you. Try to turn off the settings, restart the doorbell, set up Quiet Time again, and see if it changes. If that does not work, please let us know, and we can look into it further.
damador
I have reset the doorbell twice. I have cycled all the settings for quiet time in different combinations. I previously had two nest battery doorbells that worked without issue. I swapped out one with wired as the wired operate in below -20 temperatures. The second battery doorbell still works correctly when quiet time is on. However, the new wired doorbell does not. I'm unsure if there is some sort of issue in this heterogenous combination of two different doorbell types (wired and battery) with quiet time mode.
@damador
It may be possible that because one of your doorbell's uses a chime and the other does not, could definitely be causing Quiet Mode to not work correctly. Two opposing devices with two opposite methods to alert the user.
EmersonB
@damador I'm dropping by to ensure that everything is covered here. I hope that the information sheds some light on the issue. If you have other questions and concerns, feel free to let me know.
I appreciate the help, Brad.
janthadeus
Thanks for the help here, Brad and Emerson.
damador
There has been no solution too this issue. Product functionality of quiet time does not work. Resetting and option enable and disable does not fix issue.
Sure it's possibly two different types of google nest doorbells in the Home system is related to issue but that's untested and not a solution for someone using such a setup of relatively new devices.
damador
Partial solution. Remove the wired up battery doorbell from system. Leave only the second gen wired doorbell and then quiet time works. Readd the battery doorbell in wired setup and quiet time doesn't work again for the second generation wired doorbell. Heterogeneous install is the issue.
janthadeus
How's it going? Still need our help?
geotu
I'm having a similar issue except I only have the Wired 2nd Gen Doorbell (no mixed setup). With Quiet Time enabled, the indoor mechanical chime still rings.
janthadeus
Hi damador,
I’m sorry for the delay. Are you able to post a photo of your indoor chime wiring so we can take a closer look?
Nothing special there. The chime has front and back connections. Red are all connected to each other at chime. Black from transformer, front, back are each connected to their connector. The white nest provided circle chime attachment is on the front and transformer connections.
@damador
Have you had the chance to try and attach some photos on this thread? We would love to see what the setup looks like. Thank you for sharing what it looks like in your own words, though. It is all very helpful in troubleshooting.
damador
janthadeus
Thanks for sharing a photo of your indoor chime. Let’s sort this out —  a few questions: what’s the voltage of your transformer? What country are you located in? Could you remove the wire from the rear terminal screw? Also, has there been a recent power outage in your area?
Take a look at this wiring diagram:
Have a look at this article and let us know if you need more help: Check Nest doorbell compatibility. Also, I recommend contacting a Nest Pro near your area.
24v 40va transformer
the wiring matches that when the rear battery doorbell is detached
no recent power outages
damador
The concern is that I have a wired doorbell with a non-functional quiet time mode. It does not disable the chiming operation of the wired doorbell, only that of other wireless doorbells in the same system. The only way to silence the doorbell is the software switch that controls any ability to chime, this has no timeout like quiet time, which means we often just leave it off. This means we have a front doorbell incapable of operating like a doorbell despite being wired to the chime.
Mine is set up like this and the chime still rings in quiet mode I see the recommendation to restart the doorbell but there is no option to do this in the app. Can I only do this by taking the doorbell off and pushing the reset button on the back?
I have mine set up this way and have restarted the doorbell by pressing the button on the back for 5 seconds. Is quiet mode supposed to silence the chime? I would think this would be how it is supposed to work but it definitely doesn't work on my wired second gen nest doorbell
I have found that I can turn off the chime in the app, so this is a software issue.
Yeah, I can completely turn it off in settings of doorbell. There's just a software bug in nest system that isn't letting quiet time properly operate.
If you're still experiencing this, please fill out this form, and a higher tier of support will reach out to you with further assistance. Thank you for your patience and understanding.
EmersonB
Hello everyone,
@damador we got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Please continue the conversation there to avoid confusion here.
For those who are still not able to fill out the form yet, you may hit this link and provide all the needed information. Let me know once you’re done.
I appreciate the help, Brad and JT.
janthadeus
It's us again. We haven't received your form. Still need our help?
janthadeus
Thanks for the update. We got the form you've submitted — thanks for filling that out. I'll consider this post as complete and will lock the thread in 24 hours. Please keep an eye on your email as someone from our team will reach out to you to assist you further.
janthadeus
geotu
Hi JT,
You seem to be very responsive. I could use some help with a related issue. This thread that I started hasn't received much traction. I also chatted with two people from Google Support, and both of them didn't even understand what Quiet Time was.
https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Nest-Doorbell-Wired-2nd-Gen-Quiet-Time-...
I filled out and sent the phone
davidyoung77
I didn't see the request for the form. I Will send the form soon
