Replacement screw
sumit0836
I lost one of the small screws that are used to attach a power wire to the nest hello doorbell, Google support was not able to assist... and suggestions?
EmptyNester
Gold Product Expert
Gold Product Expert
All I can think to do is  head to the nearest hardware store with the doorbell and the (1) screw you have and see if you can buy one that works.
Rubes
Gold Product Expert
Gold Product Expert
Unfortunately parts for these cameras is non-existent from Google direct. Although for screws, you may luck out spending some time in the nuts and bolts section of your local hardware store. I believe the screws are M3x4mm with a 7mm diameter head. However you could also probably do just M3x4mm and use a washer.
aatienza
Hey sumit0836,
Appreciate the help, EmptyNester and Rubes. I'm dropping by to ensure if everything is covered here. Hope that sheds some light on the issue.
Archie
aatienza
Hey sumit0836,
Archie
aatienza
Hey sumit0836,
Archie
