Reset nest doorbell and can’t get it going again
LisaMink
My doorbell camera went offline and stayed offline.  I googled around and followed some bad advice to reset it.  Now it won’t reinstall.  The blue ring light isn’t lit and all I have is a small blinking green light where I believe is supposed to be a small blinking yellow light.  So frustrated!
David_K
Firstly, just to confirm, what model of doorbell is it? You can check here:
Technical specs for Nest cameras and doorbells - Google Nest Help
You can find the official reset steps below; scroll down to the factory reset section. Are these the steps you tried?
Restart or factory reset Nest camera or doorbell - Google Nest Help
David_K
LisaMink
I’m not sure how, but I fiddled with the wires, reconnected it to my account and then did the restart.  And phew, it’s working again.  Thanks for your help!
David_K
No problem, glad it's sorted!
LisaMink
None of Google’s pat answers address the problem of the blinking green light.  Thank you for responding though.
