03-13-2022 03:11 PM
I recently moved into a new home that already has a Nest Hello installed and firmly attached to the wall outside. I would like to connect it to my phone to setup camera and doorbell notifications, but I cannot remove the device from the wall to scan the QR code or input the 6 digit key on the back.
I do, however, have the original packaging. The following support page indicates that the serial number can be used:
https://support.google.com/googlenest/answer/9235302?hl=en
However, I do not see an option to input the serial number when I select "continue without scanning"; only the 6-digit entry key.
Is it indeed possible to setup/pair the device using the serial number on the original packaging, or is there some other way I can accomplish this without removing the device from the wall?
Thanks in advance for your assistance.
03-21-2022 11:26 AM
03-22-2022 10:22 AM
Hi Brad,
Yes, I still need help with this. Thanks.
03-25-2022 09:21 AM
Please let me know if that works for you! You should definitely have the option to input the QR code.
03-25-2022 09:44 AM
I can see you didn't really read my question carefully. I clearly said that I cannot remove the doorbell from the wall to look at the back, and that I was inquiring specifically about how the serial number (on the original packaging, not the key above the QR code) can be used to link the device to my phone.
If the serial number cannot be used this way, that's fine, although that makes the information in the troubleshooting page I linked incorrect. But I promise I know how to scan a QR code; that's not the advice I asked for.
08-10-2022 01:22 PM
I have the same issue of not being able to remove the existing Nest Hello from my door. Is there a walk around with the serial number which I have in hand? Thanks!
09-20-2022 07:36 PM
Hey cn_habs,
I'm sorry for the delayed response. If you can’t scan the QR code, you can manually type in the key or serial number.
Archie
09-26-2022 02:52 PM
Just checking in to see how the conversation is going, as there's been a lapse in activity on this thread.
09-28-2022 03:00 PM
