Sound alarm for animals on nest camera (while phone is is dnd mode)
Kq7w
Hello I have this situation I install a Google Nest indoor camera but it is actually outside so I can monitor it 24/7. And I would like to have a sound alarm whenever a cat stops by my door so I know when to feed her.
Is there a way to set an exception so that only that alarm makes a sound while the phone isn't do not disturb mode or in silent mode?
Using Android, thanks !
Matt
Cathal_S
On my Pixel 6 running Android 12 you can adjust what apps can overrule the do not disturb mode using the digital wellbeing filters.
You didn't say which Android device you are using or what version of Android it's currently on so this might be available or might be in a different setting.
Cathal
Just checking in to see how the conversation is going as there's been a lapse in activity on this thread. Thank you for your help, @Cathal_S!
Best regard,
Jeran
Hey Kq7w,
Just checking up,
Jeran
