11-12-2022 08:58 PM
6 months ago I was unable to hear the doorbell audio being played back. It sounds like it was coming through my ear piece of my phone instead of the phone's speaker. I have since then bought 3 outdoor nest Cam batteries. And with the recent android 13 update. And the Google home update. It now totally bricks my phone speakers. And audio playback is basically useless. It is so choppy and even now even lower. I just do not know what to do.
11-16-2022 09:01 AM
11-20-2022 06:59 PM
Yes I was able to restart my phone but it continues. Interesting enough when I am wearing ear buds the audio is fine but the moment I take them out and sound is suposed to come out the phones speaker. The audio glitches. This is the only app that does this!
11-21-2022 03:36 PM
I’m sorry if you're still having trouble with this. No worries, we’ll sort this out — a few questions: has the doorbell been exposed to outdoor weather? Has the doorbell suffered any drops or impacts? Is the doorbell exposed to direct sunlight for extended periods of time? Also, is the doorbell in a case or housing?
Here are the troubleshooting steps you can try:
Let me know if that helps.
11-21-2022 04:01 PM
No the doorbells aren't what the issue is. It's using the home app on my phone's speaker . All of the cameras are fine. It's when using the home app that when trying to listen to the doorbell or any of the nest security cameras. That the audio cuts out multiple times on my phone. When using Bluetooth headphones connected to my phone the audio is fine. It's when using the home app and opening up the camera tab that it immediately starts cutting my audio out. Which then continues on to every app on my phone and as soon as I close out the home app the audio goes back to normal.
11-22-2022 05:58 PM
Hey StephenE23,
Thanks for isolating the issue here. We hear you. Our team is working hard to deliver the best experience for our users — we'll take this as feedback. Keep an eye on the Google Nest Community page https://goo.gle/2JvnMRy for any updates. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Check out this link on how to file feedback.
Best
11-19-2022 02:43 PM
Hello folks,
@StephenE23 were you able to restart your Nest camera? I'd be glad to hear from you — I'd like to make sure everything is working.
I appreciate the help, Brad.
11-20-2022 06:32 PM
Thanks for the help here, Brad and Emerson.
