01-14-2025 03:58 AM
Both of my cameras went offline on Sunday 12th Jan I have restarted everything and they still won't come on line I have a Nest smart thermostat on the same wifi which is working Both cameras have worked well for 2 years without issues Both cameras can only be accessed by ladder It seems odd that both have simultaneously failed at the same time. Any ideas ? Any help would be very welcomed
01-14-2025 07:24 AM
If the electrical outlets for your cameras are easily accessible, you could try unplugging your cameras for a minute to restart them.
01-14-2025 08:17 AM
Thanks for the response. I did do that and removed the cable. I also rebooted the router and checked the internet speed which is 120mips. Still nothing
01-14-2025 09:27 AM
Unless there was some change in your Wi-Fi network on Jan. 12, or a power surge/outage, the only other possibility I can think of is that the electrical circuit(s) for the cameras is/are off.
If you want to contact Support:
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
01-14-2025 09:46 AM
Thank you so much. I will give that a shot
