09-12-2021 05:09 PM
Towards the ned of the setup i have to select the mounting options. I selected 'Magnetic Mount (in box). I am getting a message 'Something went wrong'. I am using my iphone google home app.
I am not able to understand the issues. Looking for help.
09-12-2021 05:23 PM
The only thing I can think of is do you actually have the camera sitting on the magnetic mount? It turns out that it must actually be on the mount or the camera won't wake up. (I know it sounds crazy but give it a try).
09-21-2021 03:37 PM
Wondering if you still needed assistance with this issue? It seems like your problem was solved, but I just wanted to check still. Please let me know!
09-15-2021 10:32 AM
Thank you for the response. I was able to solve the problem. There are two points:
1. The Camera has to be with the magnetic mount
2. The camera should be at the recommended height (6 to 6.5 ft)
Thank you for the quick response.
09-23-2021 11:18 AM
Hey Folks.
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
