Wall Plate Replacement
GarrettVD
I recently installed a Google Nest Hello (Wired), and the top "clip" on the wall plate/mount doesn't hold the Nest securely, as it appears to have (partially) snapped off, leaving the bottom "clip" to hold it in place, aided by a bit of scotch tape.
I was curious as to where I could get a replacement wall plate / mount? (I am located in Canada)
Thanks very much.
Thank you for your patience. I have submitted the Request for a Replacement, and here is your Case Id: 1-9156000032195
Please note: once I have submitted your replacement request, I will be locking this post.
Kalla.
