11-06-2021 06:27 AM
Hello. I recently installed a Nest Outdoor camera under my deck. When there is wind and strong gust, the recording is bad with wind noise. Any suggestions on how to reduce wind noise. Thanks.
11-06-2021 03:26 PM
Our outdoor Google Nest cameras have always picked up wind noise.
11-06-2021 06:07 PM
You can add a microphone Muff if its really bad, that will reduce the wind noise for sure
11-08-2021 05:32 AM
Hello. I am aware that Nest cameras have wind noise, I was asking how to reduce the noise if possible. Thanks.
11-11-2021 02:53 PM
Hey, Bacarl19745.
Sorry about the excessive wind noise on your camera audio. Unfortunately we don't have any official product for handling wind noise, but there are other users that have found certain workarounds for this, such as building a small deflection shield or by using a muff as @Ashepherdson mentioned. Wind is a tricky one. Hopefully you can find a solution that works well for you.
Thanks.
11-15-2021 03:08 PM
11-17-2021 03:39 PM
Hey Folks.
