05-02-2024 09:30 AM
The camera is offline, I reset and it works for 5 min then back to saying its offline.
05-03-2024 07:47 AM
Which doorbell do you actually have? Your post says "Nest app" and "Nest Doorbell (wired Gen 2)", but the only doorbell installed in the Google Nest app is the Google Nest Hello Doorbell, while the 2nd gen Google Nest Doorbell (wired) is installed in the Google Home app.
Has this issue occurred ever since you installed the doorbell? If so, you might have a weak Wi-Fi signal at your doorbell's location.
If it's a new issue and you have the newer 2nd gen Google Nest Doorbell, you could try contacting Support about whether you qualify for a warranty replacement:
