04-28-2023 12:30 PM
When using the manual pairing code, the keypad only allows for numeric entry. The code above the QR code however contains alpha and numeric. Stumped in Texas
04-28-2023 01:31 PM
When you say "manual pairing code", do you mean you selected the "continue without scanning" option instead of scanning the QR code during the install process at about 2:50 in this install video (https://support.google.com/googlenest/answer/12570869?hl=en&sjid=9732028116105598055-NA)? (The install video doesn't show the "continue without scanning" option.) If so, it seems very peculiar for this to happen; all of the 6-character Setup Codes include both alpha and numeric characters. Do you have the latest version of the Google Home app?
If it persists, you could try contacting Support:
04-28-2023 02:50 PM
So, when in doubt reinstall the app and start over. It worked (even though I had updated it). It paired! Thx B
05-03-2023 10:08 AM
Hey there sdoowbob,
It looks like you got this worked out. Thanks for letting us know what ended up clearing things up for you. I just wanted to follow up real fast to see if there was anything else you needed. If you have more questions, just let me know.
Jeff
05-03-2023 03:04 PM
Thanks. The only other thing is I would like for my android phone to "ring" when someone presses the door bell. I do get a notification but it's easy to miss. Suggestions?
05-04-2023 08:54 AM
Hey sdoowbob,
One idea I can offer is for you to change the notification tone for the doorbell's alert. If the default notification sound isn't to your liking, you could assign one that's more in line with what you're looking for.
Jeff
05-07-2023 12:45 PM
I appreciate your help, @MplsCustomer and Jeff.
05-08-2023 01:48 PM
Hi sdoowbob,
