11-22-2021 09:06 PM
I couldn't change my password on my nest cam after changing my wifi network password, so I deleted it off the home app. Now I can't get it back on the home app, even after changing my passwordback to my old password, light is green, but won't show up when trying to add to network. I just need to get it back on my home app. I've tried everything!! Help!!
12-04-2021 11:08 AM
have you been able to resolve this issue? I am experiencing the same and can nor figure it out
12-04-2021 11:08 AM
12-04-2021 11:39 AM
Yes I did! What I ended up doing is finding a reset port/button and I reset the camera and re-added it to the network. It took about 5 minutes once I figured out where the little reset port was. Its behind the camera (angle the camera down). Its a small port like a phone has. I used my phone key to reset it. Good luck!
01-05-2022 11:34 AM
01-25-2022 04:06 PM
Hey Folks.
