current drawn by wired doorbell camera in amps needed?
jackgsamsung
For the Nest Doorbell, 2nd generation wired, how much load current does the device  draw on a Video ( worst case amount of AC current) ?
EmptyNester
Silver Product Expert
Hello,  I'm an end user like you.  I'm not sure you will get the exact answer to your question.  If the transfer in your house is rated for the correct number of amp (or more) that the specs say then  you should be good to go.  And also when you say "draw on a video" I'm pretty sure there is not substantial change in the current draw.
Is there a specific problem you are running into?
Also, here is a link to the specs for the one you are asking about.  It says:
Power requirements
