doorbell camera offline
deeba28
My Google Nest Doorbell (Battery), it's telling me that the device is offline due to extreme temperature, its neither extremely hot or cold enough here to cause this issue? ( daily avg temp 3deg C to 17deg C ) I took it down charged it up, reset to it factory settings and reconnected it.  Unfortunately it is still the same, offline due to extreme temperature. Can you assist please.
@deeba28
You may need to contact Support to see if your doorbell needs to be replaced as defective:
