google cameras with flood lights code
sfsalrivas
I've lost my qr codes and dont have the serial codes for the cameras. I've looked on the actual cameras but it's not there. Suggestions?
@sfsalrivas
You can use the 6-character Setup Code (letters and numbers) that is printed on the bottom of the camera. You'll have to disconnect the power cable in order to see it. You cannot install using serial numbers.
Here's an image of the Setup Code; the actual code is much smaller and is not highlighted like this:
Juni
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the futu
Juni
janthadeus
Checking in — I just wanted to make sure if you’ve seen MplsCustomer’s response. Let me know if you need anything else.
janthadeus
Hey sfsalrivas,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
