01-12-2022 12:19 AM
I have broken the small plastic spring loaded circle off the back of my google door bell.
happened when I was taking it off the first time the recharge the battery.
I would like to get a replacement part ASAP
01-12-2022 11:00 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
