10-11-2023 08:44 AM
Why do the lock latches get stuck on the google doorbells ? So now my camera want latch on and lock
10-13-2023 10:56 AM
Hi Kimblyy,
Yikes! Sorry to hear about that. Let 's sort this out.
A blocked latch may be the cause of your Nest Doorbell's (battery) inability to secure onto the metal mounting plate. The latch may be found on the back, above the USB-C port. The latch on your door is stuck in the release position if it is not extended. First, try pressing the release button a few times to see if it resolves the situation. You may also try pressing the latch to see if it works. You will need to disassemble the latch if it does not return to its expanded position.
Let us know how it goes.
