reset camera 2nd generation camera to factory settings
carmelbewell
Does anyone know how to factory rest indoor camera on the nest cam 2nd generation?
Rubes
Due to that camera not having a factory reset button, the way to reset it is to remove it from your account and re-add it.
  1. Open the Home app or the Nest app.
  2. Tap the camera that you want to reset.
  3. Tap Settings > Remove device > confirm
  4. If you’re giving your camera to someone else, you’re done. If you want to reconnect your camera to the app, simply go through camera setup in the app again.
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
P.S Thanks for your help Rubes!
Hey Folks.
