02-20-2022 06:07 PM
I had a family member remove the doorbell to charge it. When they remounted the doorbell, they dropped it on the floor scratching the lens and there is a slight blur in video (also the black parts with the IR lights and other sensors)
Is there a replacment or accidental damage policy or similar? I did purchase this from a bricks and motar store locally. in Australia.
If there was going to be a new version being released I would recommend that the lens is moved further into the body to avoid damage?
02-21-2022 10:12 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
