04-02-2024 08:40 AM
Nest camera fails to connect to Google Home. Doorbell works. Google home fails to "see" unit. When unit is powered, it gives a chime, blue light is on and nothing more. Have restarted modem & phone. No connection. WiFi signal to area is strong. Tried using both iPhone 6S and iPad.
04-02-2024 10:06 AM
Are you installing your 2nd gen Google Nest Doorbell for the first time? I wonder if using an iPhone 6s could be an issue, since I think it can only run iOS 15.8.2, though it is supposed to work, with the Google Home app requiring iOS 15.0 or later. You could try contacting Support:
If you are reinstalling, what issue prompted you to reinstall? Did you do a factory reset (not a restart)?
