Audio for Chrome Cast to TV
AJA239
Hi there, I have set up Chromecast with Google TV on to my IOS phone and TV. Seems to be working excepting I cannot get any audio on what is playing. Do I need other devices? My set up is an only slightly smart TV with box and audio via speakers (CD unit). I don’t want to change connections each time. Any suggestions?
10 REPLIES 10
JenniferV
Hello AJA239,
Thanks for reaching out. Please try the steps listed below:
  1. Make sure the Chromecast is connected to the power outlet and the TV is on the right input.
  2. Make sure the device you're using with Chromecast is not muted (Examples: TV, mobile device, etc.).
  3. Make sure that the TV, sound bar, and/or receiver is not muted.
  4. Unplug Chromecast and plug it back in.
  5. Unplug the TV and plug it back in.
  6. Check if the no audio issue occurs when you're using different apps and/or websites.
  7. Cast the same Chromecast device on a different TV (if possible).
  8. Perform factory reset. Here's how.
Jennifer
JenniferV
It's me again. I want to make sure you're all good — how did the steps go?
Jennifer
JenniferV
Hi AJA239,
I haven’t heard from you in a while so I'll be locking this thread if there’s no update within 24 hours. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
Jennifer
AJA239
Thanks
No luck
I think it is input/output issue that we have separate speaker system for sound and everything through our box but only one hdmi input on back of box. I invested in a splitter but no luck as maybe that is going wrong direction.
We are the highest tech savvy family but not hopeless either. But this is a bit frustrating. We have a Phillips headset for individual watching and the sound comes through that but not the usual speakers and not TV
JenniferV
Thanks for getting back to us. Could you please try to plug in the Chromecast directly in your TV's HDMI port to check if you'll get the same result?
Jennifer
JenniferV
Hello AJA239,
How's it going with your Chromecast with Google TV? Do you still need help?
Jennifer
AJA239
Hi - I actually havent tried due to workload then sickness in the house. Shall try and revert.
JenniferV
Understood. I hope everyone is well. I'll wait for your update — no rush.
Regards.
Jennifer
JenniferV
Hi AJA239,
I don't want to be a nudge but I'd like to check if you were able to try the suggested step. Feel free to reach back should you still need help.
Jennifer
JenniferV
Hello there,
I haven't heard from you in a while so I’ll  be locking this thread if there’s no update within 24 hours. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
Jennifer
