06-07-2022 09:16 AM
Hello Team
I have the Chromecast with Google TV. It works well on Wifi and provided a power supply however 1080p and 4k movies struggle and buffer often.
So I got my first USB-c hub with PD 2.0 and connected it to a Dell 65w power supply. I also attached a 32GB memory stick fat32 formated. The device comes on and connects to wifi does not see a memory card or ethernet. Reseting the device Unplugging and plugging in again. Waiting 2 min each time to power reset. So I got another USB-C hub also with PD 2.0, 6 in 1 model Hoco hb16. I have the same problem.
The same problem. Now iunderstand from alot of these forums that picking a hub that will work is tricky. The ones recomended I cannot get in my country. I do know that most of these are based on a common chipset that is pretty generic.
So is there a list of tested hubs? Is there a chipset to look out for? Specks and requirements for the hub to work?
So sort of standards of compliance?
Note that not all brands are available worldwide. so generic as possible, please.
06-10-2022 04:43 AM
I am using generic hub with one usb-c, usb-a and hdmi out and works fine with all my accessories. I just had to use 30 Wh phone charger to make it work but detects everything, even usb-a to ethernet.
06-10-2022 05:06 AM
Thanks for the reply what model is yours, do you have any technical details of the model you are using?
06-10-2022 06:47 AM
Trust USB-C Multiport Adapter
I would send link, but each time I sent it, the message disappears.
06-10-2022 09:58 PM
Thank you, I am also looking for something with ethernet.
06-11-2022 06:04 PM
Thanks for the suggestion, emgi2.
ChuckStrut, while we don't have a specific brand to recommend, you may also try the ethernet adapter for Chromecast with Google TV that is sold in the Google Store. You may check here.
Jennifer
06-14-2022 06:11 PM
Hi ChuckStrut,
It's me again. I wanted to check if you have other questions and concerns. Feel free to let me know if you do.
Jennifer
06-15-2022 06:28 PM
Hello there,
Just checking in to make sure that you've seen my response. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Jennifer
