Power supply
Doona
I recently moved house and I’ve lost my chrome cast ultra power supply, I found a similar one but an error message comes up as “non standard power supply detected, to stream in 4K use the power supply included with chrome cast ultra”, I got this over 4 years ago so I don’t know where the supply is, do they sell new ones? How can I get it working again?
10 REPLIES 10
Jeran
Hey there Doona,
I apologize for the late response, thank you for being patient! Were you able to fix that power issue? If not, I'd be happy to help out, as I can imagine this issue is pretty confusing. Go ahead and check out this thread where someone had the same issue. You may need to just unplugged the power for a few seconds, and plug it back in. If that doesn't work, please let me know what kind of power supply you are using.
Jeran
Doona
It seems I’m using a regular chrome cast power supply, I read the ultra has a different power supply but I can’t seem to find one anywhere.
Jeran
Hey there Doona,
Here are the technical specifications for the different Chromecast devices. The power supply the Chromecast Ultra needs is 5 Volt DC, 1 amp power supply. Check to see if that is the power supply you are currently using.
Jeran
Jeran
Hey there Doona,
Do you have any more questions or need any additional help?
Thank you,
Jeran
Jeran
Hey there Doona,
I'm just checking up on this thread again, do you have any more questions?
Jeran
Doona
I was told you can’t use it without the original power supply, so I guess I can’t use it? The plug on the end of a 5 volt 1 amp is different, this one uses a usb plug.
Jeran
Hey there Doona,
It is true that you are supposed to use the original power supply. However, some users have been able to use another 5 Volt DC, 1 amp power supply, though it isn't recommended by Google to do so. I was curious if the one you were trying to use met those power requirements, which is why I asked. In this case, you may need to look at if you can find another Chromecast Ultra power supply second-hand, or another Chromecast device.
Jeran
Jeran
Hey Doona,
Do you have any more questions that we can address? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
Jeran
Hey there Doona,
Just checking up again, do you have any more questions that we can address?
Thank you,
Jeran
Jeran
Hey Doona,
Do you have anything else that we can help with today? If not, I'll go ahead and lock up this thread in 24 hours.
Jeran
