03-01-2024 09:24 PM
Got a 1st gen chromecast on Bell wifi 2.4ghz from Android phone apps. Up to a few weeks ago all was fine. Since then, suddenly, pixelized images, continuous buffering sometimes every 10+ seconds, image and sound out of phase sometimes. Got this from all streaming apps (Netflix, prime, crave, tou.tv, recording on Bell fibe app). I resetted both router and chromecast by unplugging... No difference.
When I play same recordings from Bell pvr all is good.
Any clue? Chromecast done? Bell wifi problem?
03-02-2024 06:27 AM
You can try to isolate the issue by connecting it to a Wifi hotspot. Note you will need 2 devices to set this up.
If the issue doesn't occur when using a Wifi hotspot, that suggests an issue with your Wifi network and I'd suggest contacting your internet service provider. If the issue still occurs when using the Wifi hotspot, that suggests an issue with the Chromecast, and I'd recommend factory resetting it. Note unplugging it does not reset it, you need to follow the steps I'll link below.
03-02-2024 06:27 AM
03-04-2024 03:50 PM
Factory reset. Problem solved!
03-02-2024 06:42 AM
Thank you David. I actually had the same idea last night while trying to sleep,😴 ans i will try that today, see if it works. I will report back.
