3-speed fancoil unit + underfloor heating
Anton5
Hi!
Please advice if its possible to control 3-speed fan-coil unit working only for cooling + heating with 1 stage? (cooling source is heat pump with hydronic distribution to fancoil units in each room).
I know there is 3-speed fan option, but can it be set as cooling logic?
Hi Anton5,
Thanks for checking it with us. I'm sorry for the delay. I'd like to take a closer look at it. A few questions: what is the make and model of your system? In what country are you located? Please take a photo and share with us the wires you have on your system's control board. Ensure that the labels are visible.
