Automation Script Help Reboot Nest Wifi Pro
sbeachx75
Hi, everyone! Currently, I have my Nest Wifi Pro plugged into a smart outlet, which is scheduled to turn off at 03:00 every Sunday and back on at 03:01. I was hoping through the script editor, I would be able to automate this without the 3rd party plug and free it up for something else. I can't seem to clear the script of errors and I'm not really sure how to go about doing so. The very basic code is as follows:
metadata:
  description: Reboot Wifi network every Sunday morning at 3 AM.
automations:
  starters:
    - type: time.schedule
      at: 03:00 # HH:MM (24 hours format).
      weekdays:
        - SUN
  actions:
    - type: device.command.Reboot
      devices: Blue Point - Living Room
 "Blue Point" being my router's device name in Google Home and "Living Room" being its location.
The returned error, however, reads:
[Blue Point - Living Room] is an invalid device name. The list of valid device names:
It lists all of my devices connected to Google Home, including my Wifi network name, so I plugged that into the script instead, but it returns this error:
[device.command.Reboot] is not supported by device. The list of supported commands: [].
 What am I doing wrong here?
David_K
You're not doing anything wrong, the problem is that Nest Wifi doesn't natively support the reboot command that you're trying to use.
David_K
Oh, that is... an interesting compatibility choice by Google. Thanks for the affirmation.
matteh
https://developers.home.google.com/automations/schema/reference/entity/sht_device/reboot_command
"Devices that support rebooting, such as routers." - Their only example is routers and routers are the devices that don't work with the command.
