Ayuda con Chromecast
Er3nJa3ger
Tengo un Chromecast ultra y al configurarlo me dice que ya está vinculado a otro dispositivo, que lo restablezca de fabrica, pero no tiene un dispositivo vinculado
David_K
Did you reset by using the physical button on the device? While the Chromecast is plugged into the TV and powered, hold down the button on the side of the Chromecast. The LED should begin to blink orange. When the LED light turns solid white, release the button and the Chromecast should then restart.
Once reset, if you experience issues during the setup, try these steps:
Need help with setup? Troubleshoot common Chromeca… - Google Nest Community
Kimy
Thanks for your help here, @David_K.
@Er3nJa3ger, I hope you've found the answer you're looking for. If you're still in need of assistance, please let us know, as we would be happy to answer any questions you may have.
Kimy
Kimy
Hi Er3nJa3ger,
Kimy
Muddi
Hey Er3nJa3ger,
Just bumping this up to make sure that you've seen our responses. I'll lock this thread if we won't hear from you in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
