10-30-2022 01:29 PM
Can't connect camera to multiple devices... also nest camera is very hot to touch (it's not in the sun)
10-30-2022 02:19 PM
Which Google Nest camera do you have? Can you see it at all in the Google Nest app or the Google Home app? Have you tried restarting the camera? https://support.google.com/googlenest/answer/9252162?hl=en
10-31-2022 03:59 PM - edited 10-31-2022 04:10 PM
Oh no! We’re sorry to hear that. Let’s check — could you fill out this form so we could further investigate?
Please stop using your camera as it may cause harm to you. In the meantime, unplug it from the power outlet.
I appreciate the help here, MplsCustomer.
11-03-2022 09:51 PM
It's us again. Were you able to fill out the form?
I appreciate the help, JT.
Archie
11-07-2022 10:10 AM
Hello again,
Do you still need help with your device? If so, kindly fill out this form.
Dan
11-10-2022 10:19 AM - edited 11-10-2022 10:21 AM
We haven’t heard back from you, I'll be locking this thread in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Juni
11-13-2022 05:50 PM
Hey ub1badboy,
I just wanted to jump in real fast to see if you saw Emerson's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks for chiming in, Archie, Dan, Juni and Emerson.
11-10-2022 11:19 AM
Still trying to disconnect from my account on the app so a family member can use it. I've tried deleting the app... that did not work because goggle would not let me switch to new user on there device using the same nest app.
11-10-2022 11:50 AM
If you want to turn over ownership of a Google Nest camera, you need to remove it from the Google Nest app or the Google Home app (depending on the camera) while you are logged onto the Google account and Wi-Fi used to set it up, and then do a factory reset. Then the new user can install it.
11-10-2022 12:01 PM
@ub1badboy thanks for getting back to us. For you to disconnect your account from your Nest camera you need to remove it first from your Nest app and reset the actual Nest camera to the factory default. After that, the Nest camera can be connected to a different account.
I appreciate the help, @Juni, @Dan, @Jt, @MplsCustomer and Archie.
11-14-2022 06:01 PM
