Does anyone know what motion sensors are compatible with routines?
whatuk
Hi, I was wondering is anyone knew what motion sensors are compatible with routines?
I bought a nest camera, only to find out that it can't trigger anything. Which isn't very helpful as a security device.
So now I was looking into motion sensors. It seems like the hue one would work, and maybe the eve as that works with matter. But then I can't find any definitive information on it, and it just seems super sketchy.
Does anyone know?
Thanks!
Kacperhq
10 REPLIES 10
Kacperhq
hi @whatuk
i have hue motion sensor conected to google home. It can be use as a triger to start automation.
At one of my home i have it conneted using matter and in other as a google service, works in bouth cases
whatuk
Ah amazing, thank you Kacperhq. Out of interest, do you know if it works on its own without the bridge?
Kacperhq
@whatuk
Hue can use matter only when connected to hue bridge. Eve motion sensor should connect directly using matter as far as I know
whatuk
Ah I see. Thank you! Is there any actual info from google on this? They seem to say you can do it, but then there's no actual information on what's compatible.
whatuk
And also just to confirm, if I wanted a light and a song to play when the sensor detected motion, that would work?
Kacperhq
Yes it's possible.
whatuk
Thank you!
Mlabrador
Thanks for posting in the community and apologies for the late response.
@Kacperhq, thanks for all the help. I appreciate it.
@whatuk, @xtimex, to learn more about matter, you can check this article. I'll consider this thread as complete and will close it after 24 hours. If you have other questions feel free to create a new thread.
What you need
  • A Google Account
  • A home Wi-Fi network
  • For devices that use Thread, you need a Thread Border Router to complete setup
  • A mobile phone or tablet with:
    • Android 8.1 or later
    • Google Play services version 22.48.14 or later
    • Bluetooth Low Energy (BLE) 4.2 or higher
  • Latest version of the Google Home app
  • A Matter-enabled smart home device. Look for the Matter logo on the package.
  • A Matter-enabled Google hub
Nikki
xtimex
I have TUYA sensors for door and motion, the application Google Home detects them, but cannot use them as a trigger under automation👎
whatuk
Ah really. Yeah maybe that's the "matter" thing. I think I'll wait until eve release the matter updated versions.
