Extending nest connect range
Lsrothstein
I need to add yale locks to my nest account, but they are located in an out building more than 50 ft from my house. How can I extend the nest connect range?
David_K
If moving your Nest Connect closer to the lock but still in Wi-Fi range isn't possible, you can use multiple Nest Connects to extend the range.
David_K
The problem is not the distance to the lock but the distance between nest connects.  They are in different building more than 50 ft apart.  How can I extend the range between the nest connects.
Do you not have Wi-Fi coverage in the other building?
Nest Connect is designed to connect the lock to the Wi-Fi network, so it needs to be in range of your Wi-Fi network. It sounds like you'd be better off ensuring you have Wi-Fi coverage where it's needed, than stringing a bunch of Nest Connects together, because they're not designed to do that.
Bogey1
I thought Nest Connect range from Nest-Yale Lock is max 50 Ft. However you van connect upto Four Nest-Connect to same Nest-Yale Lock. I ASSUME … 4 x 50’ =200’ wi-fi connectivity?? 🤷🏽‍♂️
Can’t Extend Range between Nest-Connect past 50ft max. However I read you can connect maximum 4 Nest-Connect to one Nest-Yale Lock. I “Assume” 4x50ft = 200ft Range 🤷🏽‍♂️
