10-24-2022 02:20 PM
I could say something to my Google Home speaker at a low volume in one room, but frequently a different device in another room will answer me or execute the command I gave.
For example, I used to be able to tell my bathroom speaker to play music with no problem. But now instead of playing the music from the bathroom speaker I gave the command to, it will send the command to my TV in a different part of the house and play the music there. Having to repeat these commands multiple times on top of power cycling the devices makes for a very frustrating experience.
11-03-2022 12:33 PM
Hi roarfrom44,
That certainly hasn't been easy for you ― let’s check this out.
Few questions:What Google Home/Nest speaker do you have? Does your TV have a built-in Chromecast or a Chromecast dongle? If yes, what Chromecast do you use? Does it happen when playing music or with any other commands?
Could you do a reboot first starting with your WiFi router, TV, then your Google Home/Nest speaker. Restarting your phone might also help. Also, try the steps below:
You can also check out this link for more information and troubleshooting steps.
Tell me how it goes.
Dan
11-06-2022 11:34 AM
I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Dan
11-07-2022 11:35 AM
Hello again,
Dan
