09-20-2021 09:29 PM
Google is doing well with general voice commands however with regard to home automation I'd like to know where the controls are to enable routines for Motion and Contact.
I've found it very limiting using Google for my home automation add I'm unable make use of door/window sensors even with 3rd party work arounds.
Any ideas as to when/Google might add these features? The number of things that play nice with Google is very limited.
09-24-2021 11:06 AM
Hi mc,
Thanks for reaching out! I understand your concern. I appreciate you taking the time to share your ideas.
Unfortunately, I cannot answer your question as I do not have any information or knowledge regarding future products in general. I appreciate your feedback and will share it with the team.
You can also send feedback about this issue by using your device or the Google Home App. Check this link for more steps.
I appreciate your patience and thank you for your time.
09-27-2021 10:00 AM
Hi All,
It's been a few days since we have heard from you. Just checking to see if you have any other questions or concerns. Thank you.
09-27-2021 12:42 PM
Thank you. I submitted my feedback using what you shared as well.
Is there any existing method of integrating with motion or contact sensor available that I'm unaware?
10-30-2021 05:47 AM
Google is garbage for automation, if you want these features you need to get Alexa. Alexa doesn't support everything but it's better that google. I bought cheap tuya ZigBee sensors for about 25$ each, along with a zigbee hub also around 25$ Alexa should be able to do what you want. I got this sensor
11-18-2021 01:12 PM
Hello SomeoneSinister,
Thanks for jumping on this thread and sharing your comments.
11-18-2021 01:11 PM
Hi mc,
Thanks for your patience and apologies about the delay. At this time, there are no alternative suggestions I can share but do know sending in feedback, (which you did, so thank you!) is super helpful so our team has this information.
I recommend staying tuned to our different social channels for updates as new features become available. Thanks again!
11-22-2021 03:16 PM
Hi All,
We haven't heard any updates from you. I'll go ahead and lock this thread. If you have any new questions or concerns, please feel free to reach out and create a new thread. Have a nice day.
