Google Mesh Wifi vs. HUB
rashan1717
I have a broadband connection and a HUB.
How do I connect my Google Mesh?
Does it goes from the broadband router to the hub and then into the Mesh?
BR,
Rasmus
David_K
Which model of Wifi device do you have? Google Wifi, Nest Wifi, or Nest Wifi Pro? Click here to check.
What exactly do you mean by hub?
Although Nest Wifi is designed to replace your router, some ISPs provide a combination modem/router (a modem and router in the same device), which may mean that's not possible. Typically, you'll connect an ethernet cable to your primary Wifi point or Nest Wifi router's WAN port, then connect the other end to your modem or combination modem/router.
I'll link the detailed setup steps below.
Set up Google Wifi - Google Nest Help
Set up Nest Wifi Pro or Nest Wifi - Google Nest Help
Azarco
davidking, thanks for the help and for providing that helpful links.
rashan1717, checking back in if the steps and links provided above answers your questions. Let us know by updating this thread and the Community will be happy to lend a hand.
Alex
Azarco
Hello rashan1717,
It's me again. I don't want to be a nudge but I'd like to check if you still have other questions?
Alex
Princesss
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest speakers and we'd be glad to assist you further.
Princess
