11-26-2023 05:27 AM
I have a Govee home wifi thermometer/hygrometer and it says the device can be linked to Home and is supposed to tell me temperature and humidity. I've synced the device with Home, but all that is displayed is temperature. Not sure if I did something wrong or the hygrometer is only partially compatible? Any advice would be greatly appreciated.
11-28-2023 12:45 PM
Hey Becker2900,
Thanks for reaching out to the Community. I’d be glad to help you with this. Let’s check it out.
To make sure everything is up-to-date, please try the following steps:
Let me know how it goes.
Lance
01-16-2024 02:06 PM
Useless advice, as usual.
03-12-2024 03:37 PM
I have the same issue. No help apparently...
03-12-2024 04:24 PM
Hi Lance. I have the sane issue. I tried this and it did absolutely nothing
08-14-2024 04:56 AM
Hey Lance,
this is issue is still not fixed. Can you please take a look at why this function is not working?
10-27-2024 04:24 PM
Please look at my latest post...
2 weeks ago
Link??
12-17-2023 08:42 AM
I have the same problem. Trying to use this for automation of a fan. I can set the automation to use the humidity value. However google integration is not reading the humidity value. It only is reading the temperature. Says humidity is unavailable.
06-16-2024 10:51 PM
Same situation with me. Says Humidity Unavailable. The whole reason i bought these was to try automate my place based on humidity levels.
06-29-2024 06:38 AM
Me too! No use to me without humidity readings.
06-29-2024 09:16 AM
Surprise, surprise - it has now started working properly, giving both temperature and humidity. (Only three hours after my previous post.)
06-29-2024 09:40 AM
Sadly still not working for me. Humidity not ahowing only temperature. All devices fully updated. I got same automation working correctly with home assistant now so I dont need the google automation. However this goes to show the issue is definitely with the google integration.
06-29-2024 05:07 PM
What did you try? Mines still the same 2 weeks later.
2 weeks ago
How??
06-30-2024 03:46 AM
2 weeks ago
Mine *only* shows humidity, and I need temperature too, to automate a space heater to keep my greenhouse warm 😞
06-30-2024 03:50 AM
Now it's back working again: perhaps you have to leave the Google Home app looking at the sensor until the sensor sends it next update (and if you've configured the sensor to make the battery last, that could be a couple of hours).
07-04-2024 07:35 PM
Funny thing is that while humidity does not show up in Google Home, it does show up in Alexa.
But in Alexa it does not show temperature ;(
07-04-2024 09:02 PM
From what I can see. When the device refreshes the data shows up for a few minutes. Then disappears. So any automations would need to trigger from the temp value. Should be an easy fix for them to hold the values between refreshes.
07-05-2024 04:41 AM
In Google Home the TEMPERATURE stays fine. The HUMIDITY is unavailable. But i did see it once and thought it was initial setup glitch, but then humidity disappeared.
BTW is saw this issue in at least 2 different devices, the Bluetooth hydrometer and now with WiFi one.
08-14-2024 04:54 AM
Hey is there any update on this please? Same issue, purchased the Govee hygrometer to control a smart plug with my humidifier. All I see is temperature, even though I can set the automation to specifically select humidity. The problem is humidity does not show in the app and the switch will just run or stop if I press activate. Does not work at all.
08-15-2024 12:03 PM
Has anyone had any luck getting the humidity working? Mine is having this issue too.
08-16-2024 05:51 AM
Every now and again the humidity reading shows up, but I can't detect any pattern.
08-17-2024 02:28 AM
I have had nothing but terrible customer service from Govee who clearly do not care about their devices integration in Google Home. Automations in the Govee app are unreliable at best. FYI my thermometer/hygrometer is reporting humidity only to Google Home in UK.
09-01-2024 06:25 AM
Same issue here. Temp and humidity are shown in the govee app, but in Google home it shows the temp and the humidity shows : unavailable.
Seems for me, that is a sync problem between govee and Google home.
Please fix that 🙂
10-10-2024 10:42 AM
Same issue...only temperature is displayed. Please fix.
10-22-2024 04:29 AM
The issue I'm having is that I can view the temperature when I look at devices, but when I try to set an automation, it can only shows humidity as an option. I'm trying to get a fan to run based on temperature. *Sigh*
10-22-2024 04:48 AM
I fixed mine by getting home assistant. It can share the device back with Google and Google sees both sensors clearly. Now I have the best of both worlds.
10-26-2024 03:51 AM
Same issue here... would be great if Google and/or Govee find a solution
10-27-2024 04:23 PM
I think I might have found the root cause. Google Home can only interpret whole numbers/integers e.g. when Govee sends 54.0 google home displays the correct humidity, when Govee sends 54.1 google displays "humidity unavailable". Now we only need a fix...
11-16-2024 05:18 AM
FYI: I have reported this issue as Bug to Google:
