How can I get my Google Nest Hub Max to read a specific notification from my Android phone?
IgorTom
Hi everyone, I have a Google Nest Hub Max, and I would like to find a way to have it read a specific notification from my Android phone. Ideally, I would like the Nest Hub Max to automatically read the notification as soon as I receive it on my phone. I have already tried using Google Assistant, but it doesn't seem to provide a direct solution for this. Does anyone know of a method or a workaround that could help me achieve this? Any suggestions or guidance would be much appreciated. Thank you!
Cathal_S
Try researching using 'Tasker' and 'Autocast' apps. Linked below is a reddit post that might help you on the way.
https://www.reddit.com/r/googlehome/comments/mxcd4k/help_please_tasker_push_notifications_to_google/
Cathal
IgorTom
Thanks 👍
LovelyM
@Cathal_S, I appreciate your help.
@IgorTom, I want to check if you've tried the suggestions on the website provided above. If you wish to have this feature without using third-party apps, send feedback since our product team continuously adds and improves features that are suggested by our users.
Let us know if you have additional questions or concerns about your device; otherwise, I'll close the thread after 24 hours.
Lovely
