10-12-2022 12:36 PM
I just got my Nest Hub max and the camera doesn't work for duo calls it wont turn on at all. Ive trouble shoot everything and red others same issues and tried what the tried and nothing! Do i need to suscribe to something just to use it for video calls on duo?i do t ha e the Nest aware...do i need this? I dont need security camera on my nest hub. Where can i get help on this or is it broken and should i sent it back?
10-17-2022 12:11 PM
Hi MillieG,
That certainly hasn't been easy for you ― let’s check this out.
Could I know what the exact response or message is when making duo calls? Is your built-in Nest camera fully setup? Since you've specify Google Duo calling, does that mean the camera is working when you ask to turn on the camera? Does the one you're calling can see you via the duo app?
Try these steps:
Also, click these links Turn Nest camera on or off and Nest Cam on Google Nest Hub Max to further the troubleshooting and information about the set up.
Keep me posted.
Dan
10-20-2022 12:20 PM
Hi MillieG,
I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Dan
10-21-2022 12:43 PM
Hi MillieG
Dan
