08-01-2022 03:53 PM
I have a Leviton ZW4SF-1BW linked to a SmartThings hub v2. It’s showing up correctly in SmartThings and I can control the fan speed via the SmartThings app. However, when I pair it to my Google Home account it shows up as a Fan (Switch) and does not give me the option to change the speed, only turn it on/off.
Has anyone else had this issue before?
10-01-2022 09:14 AM
Having the exact same problem. Anyone have a solution?
10-01-2022 09:38 AM
I finally got it to work by switching the type in the Google Home app to "dimmer"
10-01-2022 02:55 PM
Thank you, but my list of common device  types in the Google Home Ap does not contain dimmer.  How did you set that?
thanks
10-01-2022 03:17 PM
Sorry, I meant "Switch", not dimmer.
I have mine set to Switch. Then I set up custom routines so that medium = 50%, high = 75%, etc.
10-07-2022 11:55 AM
Thecker3, thanks for updating the Community of your resolution — it's a big help.
JBarbaccia, have you had the chance to try the steps suggested by Thecker3? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Alex
10-08-2022 04:43 PM
I tried and only have off/on functionality. Leviton really needs to remove their ‘works with Google ‘ labeling as it does not.
10-11-2022 01:57 PM
Hi JBarbaccia,
Thanks for trying the steps. Have you already contacted Leviton regarding this?
Princess
10-14-2022 02:21 PM
Hi JBarbaccia,
Chiming in-- have you had the chance to contact Leviton? Let us know if you have additional questions, otherwise we'll be locking the thread.
Princess
10-15-2022 04:33 PM
Mel
