Light keep going on by thenselves
theres56
Light are not set to go on but all 4 lights go on twice a day how do I stop them from going on?
Apsilon778
Can you give me detail when they go off? I would suggest starting with checking your automation history in the google home app and see what routines are triggering that prompts the lights to turn off or on. You can check the routines under the automations section and history under activity.
Apsilon
"I fight for the users"
