Lights on X minutes ahead of alarm
K8baker
I am looking to set up a morning routine to mimic my old wake up light. I would like to turn on my smart light at a time ahead of the alarm I have set for the morning. I can only figure out how to 1) turn the light for a set time (would require manually linking to alarm) or sunrise or 2) once I stop my alarm, turn the light on.
Thanks
You could say "Wake-up [Light name] at 6am and then set an Alarm for 10 minutes later.
But Light brands that work with the "Wake-up" command is limited. My Kasa bulb worked, but LIFX and Tuya didn't.
With Alexa I don't need to use 2 different commands to achieve the same result and hear music as the alarm tone...
 https://youtube.com/shorts/lGOr2pytgOQ?feature=share
K8baker
Should have mentioned that I'm working with a lamp on smart plug rather than a smart bulb.
"Turn on Lamp at 7am"
"Set Alarm for 7 10 am"
Jeremyg
Hi folks!
Thanks for reaching out to the community @K8bakerand thank you for your interest in helping @SmartHomeH-TAGS. I am sorry that you are having issues trying to set up a morning routine to mimic your old wake-up light, but no need to worry; help is here. We appreciate all of your previous troubleshooting efforts. I need to know if you could set the morning routine with the troubleshooting steps provided by @SmartHomeH-TAGS.
I'll be waiting for your response.
Jeremy.
