07-31-2024 10:23 AM
I have a Google Nest Hub Max and created some routines for broadcasting to it.
Today when I try to edit an existing one, script editor states "assistant.command.Broadcast" is not supported by device.
If I try to create a new routine, it does not list assistant.command.Broadcast as a supported command for the nest hub device.
08-08-2024 02:19 PM
Hey @wedge11383
I'm sorry for the inconvenience, the team is looking into this. Could you share a few additional details in the meantime?
What version of the Google Home app are you using, iOS or Android? Would you also be able to provide the version number for the app?
Are you currently enrolled in Public Preview through the Google Home app?
Thank you in advance, I'll provide more updates as I have them.
Kelan
08-15-2024 04:50 PM
Hi I have the same issue. I have 3 nest hub displays and one nest hub max. the max does not appear in the routines as an option for actions.
08-21-2024 11:07 AM
Android
In public Preview
Version 3.21.1.8
