06-02-2022 11:28 AM
I have searched everywhere and cannot find a solution to this request. I have google home setup with multiple Nest speakers throughout my home. I like to play music on multiple speakers throughout the house at a time for entertaining. I want to be able to play music inside and outside in the backyard at the same time though. I figured a smart portable speaker would be best so I don't have to worry about it getting wet or plugging it in. I just purchased the Sonos Move since it says it has Google built in. I figured I’d be able to add it to a speaker group and play at the same time as my interior nest speakers. I can add it to Google Home but that’s about it. Won’t play music with the other speakers throughout my house. Are there any other options to be able to achieve this? I don’t mind implementing a workaround if needed. Seems like a simple request but so far I’ve been out of luck. And I don’t want to swap out all my interior speakers with sonos either. Even if I do that, they don’t fully integrate with my smart home accessories.
06-08-2022 01:56 PM
Hey Skraw,
It is possible to create a speaker group with compatible devices and you can group speakers, Smart Displays, and Smart Clocks in any combination.
However, this feature doesn't work on Bose or Sonos speakers that have the Google Assistant.
Hope this helps!
Alex
06-13-2022 10:31 AM
Hey Skraw,
Checking back in — are you able to create a speaker group for your devices? Feel free to respond to this thread if you have additional questions or concerns and I'd be glad to answer it for you.
Alex
06-13-2022 11:07 AM
I was able to add the Bose to a speaker group and am able to play music through that and also the rest of my Google speakers at the same time.
06-13-2022 05:24 PM
Hi Skraw,
That's great to hear! Feel free to reply to this thread if you have any questions or concern.
Alex
06-16-2022 05:26 PM
Hi Skraw,
As we got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread if we won't hear back from you again in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Kind regards,
Alex
